by Merlot man » Sun, 02 Feb 2014 12:01 +0000
Hello all, I've taken out my rear subframe and diff . The diff seems loose in its rubber mounts so im thinking of changing them out . I've a few questions 1 how hard a job is it to take these out without a press 2 how is this done ! 3 witch mounts to use I've seen il motorsport or oem ones ,I am not looking for more noise/vibration into the car but am as always keen on better handling ! I'd be interested in hearing from people how have done such a job . Thanks in advance, Brian
]96 na Merlot edition. sold 99 nb 10th anniversary 93 na s ltd
Merlot man
by MX5Spares » Sun, 02 Feb 2014 9:10 +0000
Hi Brian ,s car came in years ago and it had 4 aluminium plates ,proper dished types,two were thin and two were thicker over and under the bushes. Still have them but never really figured what support to diff mountings they gave .Any ideas ,you can have them FOC if there any use for what you want
by Steve » Sun, 02 Feb 2014 8:26 +0000
have heard of people using void fillers and getting good results. I suspect the ones autocheck have are probably alu versions of them? Here's what they look like : http://www.priracing.com/product.php/26 ... ill-bushesand installed : http://www.mx5nutz.com/forum/index.php? ... 9&p=990511Heres a howto on removal : http://www.miataturbo.net/suspension-br ... ngs-63527/and this : www.949racing.com/server/17493.pdf
- Site Admin
by scallan » Sun, 02 Feb 2014 10:53 +0000
I picked up 2 sets of flo flex poly diff bushes. Have only fitted them to the drift car yet will do the road car in the next few weeks but seemed to work perfect on the drift car as the bushes that were in it were fucked. I know alot of ppl dont like flo flex but i couldnt pass them by when only €30 a set.
scallan
by MX5Spares » Sun, 02 Feb 2014 11:41 +0000
No these are alumimiun spacers top an bottom of mountings
by sidewaysreilly » Mon, 03 Feb 2014 12:40 +0000
How will this aid handling? It will stop axle tramp alright but handling?
by MX5Spares » Mon, 03 Feb 2014 7:43 +0000
Don't know but they were fitted to the blue one we scrapped from Mayo and it had loads of mods on it but I don't really see why they would help unless to stiffen movement of diff??
by Steve » Mon, 03 Feb 2014 9:59 +0000
- Site Admin
by MX5Spares » Mon, 03 Feb 2014 11:53 +0000
150 dollars ...........Brian they are 20w e now...
by Steve » Tue, 04 Feb 2014 12:22 +0000
LOL
- Site Admin
by Merlot man » Tue, 04 Feb 2014 3:00 +0000
Thanks lads for all of your help , Steve are mx5's all you think about ! lots of good stuff there ,thanks My main cause for concern was the fact that the diff mounting captive bolt on the subframe is smaller than the inside dia of the diff bush sleave [not for the first time I,ve had this problem!!!!] The bolt is not worn as it still has paint on it ,I was wondering if the those sleaves are prone to wear . As for the handiling what i think i mean is that i dont want lots of noise,vibration,harshness coming into the car if i cdange to stiffer mounting bushes . Thanks again anymore thoughts? Brian
Merlot man
by MX5Spares » Tue, 04 Feb 2014 10:15 +0000
Looking at the net, the aluminium bushes we have seem to replace the original rubber out of the bracket itself
by sidewaysreilly » Fri, 07 Feb 2014 12:05 +0000
You will have way more NVH transmitted lad. Noise Vibration Harshness.
by Merlot man » Fri, 07 Feb 2014 12:40 +0000
sidewaysreilly wrote:You will have way more NVH transmitted lad. Noise Vibration Harshness.
Thanks Sideways I thought that might be the case . Ive sent fm in America an email about their stiffer mounts and they said the same, so that's that . As I said my main concern was the fact that the mounting bush inner sleave diameter is smaller than the bolt in the subframe , the rubber is not new but dos'nt look to bad but then Im no expert . Thanks again for all your help lads Brian
Merlot man
by MX5Spares » Fri, 07 Feb 2014 8:39 +0000
Brian ,once nuts are tight there should be no problem as it was built like that. What the difference in sizes of holes/bolts .You could put sleeve in but you will find its minimal
