Mark 2.5 passenger seat
Postby Paschal » Fri, 20 Mar 2015 7:11 +0000
Hoping someone can help. I have a problem with the air bag sensor in the passenger seat (it detects whether someone is sitting in the seat and activates the air bag. It also doubles as a mechanism to detect a Mazda approved child seat). Anyway, it looks as if the sensor is all crumpled up under the upholstery with some of it poking through. This, I think, is why the air bag lights are displayed on the dash. So, to cut a long story short, I am on the look out for a mark 2.5 (2001) passenger seat. Unfortunately, Robert does not have one in stock, can anyone else help. NCT overdue. Thanks for help Paschal
Re: Mark 2.5 passenger seat
Postby sidewaysreilly » Fri, 20 Mar 2015 10:17 +0000
try to find what resistance the pad sensor is (google) and fit a resistor of the same value into the plug for the pad . This will fool the ecu . Might buy time till you get a seat.
Postby Real Rayzor » Sat, 21 Mar 2015 4:17 +0000
Can you borrow anyone seat for the NCT. Where you based.
Real Rayzor
Postby Merlot man » Sat, 21 Mar 2015 10:32 +0000
Hello pascal
That sounds like a good idea about borrowing a seat , mine are mk2so no good
Someone must have one with a airbag senser
Good luck with it
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Postby Paschal » Sun, 22 Mar 2015 9:25 +0000
Real Rayzor wrote:Can you borrow anyone seat for the NCT. Where you based.
Hi I am based in Tullamore. Don't have an NCT appointment yet as I am only putting the car back on the road on April 1st. Borrowing a seat is an option; I will see if I can source a replacement before I go begging (and borrowing), assuming the sensor is my problem
Postby davith501 » Sun, 22 Mar 2015 9:59 +0000
Could you take upholstery off and see what's happening with that sensor..source new one and replace..
Icon
RS
Mk1
davith501
Postby Steve » Wed, 25 Mar 2015 10:59 +0000
have you checked the connectors under both seats are connected up firmly? They can come loose from forward/back motion.
I have mk2.5 seats, will check this eve if they have wiring (you can have the sensor + wiring if I do), you are more than welcome to borrow it for NCT.
Postby sidewaysreilly » Thu, 26 Mar 2015 12:00 +0000
Paschal, you can put a resistor across the plug when you disconnect it from the seat pad.
Steve or someone handy on here may be able to find the correct resistance of a working seat unit using a multimeter set to ohms.
Then you can get a resistor of a similar rating to fool the ecu and put the light out.
Problem is, passenger bag wont deploy in an accident so its only a temporary fix to pass the nct.
Postby MX5Spares » Thu, 26 Mar 2015 7:41 +0000
Pascal give me a call ,I might be able to sort something for you 086 8226506
Postby Steve » Fri, 27 Mar 2015 7:10 +0000
confirmed I have wiring under my passenger seat.
Postby Paschal » Sat, 28 Mar 2015 1:09 +0000
Thanks for all the replies. Looks like Robert will be able to sort me out.
Postby Steve » Sun, 29 Mar 2015 12:05 +0000
great stuff!!
Postby Paschal » Sat, 04 Apr 2015 8:53 +0000
Robert got me sorted yesterday. New seat fitted and all lights out. Good days work. Thanks Robert.
Postby MX5Spares » Sat, 04 Apr 2015 10:24 +0000
No problem ,Thanks
