Throttle bodies and MegasquirtJust purchased set throttle bodies and DanSt inlet manifold PLUS megasquirt 2 for my Mk1 .Over 1500 pounds NEW. I will post pics when I have them fitted
Re: Throttle bodies and MegasquirtMmmm, that will sound good.
Re: Throttle bodies and MegasquirtHopefully but I have VVT engine in my mk1 1.8 so will need to check out either "locking" the vvt or fit non vvt head .No too bad either way and if I fit non vvt head I might get it uprated a bit
Re: Throttle bodies and MegasquirtOh jebus... will sound fantastic. Who did you buy the ecu from?
Re: Throttle bodies and Megasquirtgot it on ebay , a chap in england was doing a turbo conversion and was doing away with the carbs as he wanted more power
Re: Throttle bodies and MegasquirtAny "experts" that can assist with fitting/setting up etc
Re: Throttle bodies and MegasquirtI'll give you a hand with the ecu if you need it.
Re: Throttle bodies and MegasquirtHi Andrew ,thanks.I will give you a shout nearer the time.Its Megasquirt 2 but not sure my connectors will fit straight in to it?
