Postby mrges » Fri, 07 Apr 2023 7:10 +0000
So much going on with your car - keep the updates (and photos) coming!
Postby mrges » Fri, 07 Apr 2023 7:11 +0000
Gave Stripey a quick wash, then a 60km drive. Felt great. And the now €56 yearly tax added to the experience!!!
Postby notch000 » Tue, 11 Apr 2023 10:41 +0000
mrges wrote:So much going on with your car - keep the updates (and photos) coming!
I have the car 9 yrs and it was pretty rough & unloved when I got it, only catching up to all these odd jobs jobs now. we have 2nd kid due in July so trying to get a few jobs doing before that put the brake on the projects. Will keep ye updated otherwise. The original owner got in touch a couple of years ago and wanted to see the car again, so I'm trying in my head to get it as presentable & drivable as possible before I do that, he doesn't want it back or anything but was very happy to hear it was still in the road and getting looked after.
edit
I have the passenger side front suspension stripped now too, ball joint are some bugger to break free. Will start cleaning up the arms next and get old bushes out next.
notch000
Postby notch000 » Thu, 27 Apr 2023 1:16 +0000
i tried to pull the front end control arm bushing out last night, went with the threaded bar method.
https://youtu.be/zVgOLvjCOW8
The internet said it was easy, of course it was. Was too much for the impact gun to manage and I stripped some bars too. I ended doing two by hand with the breakers bar. half a turn at a time. I did 2 of 8 bushs in 90mins last night........
Anyone got an easier method >? i might just ask a garage to break them out on their press,
https://photos.app.goo.gl/EPFwnEGtZ43og39G9
notch000
Postby Pops » Fri, 28 Apr 2023 12:19 +0000
notch000 wrote:i tried to pull the front end control arm bushing out last night, went with the threaded bar method.
To help removing the old bushes you can use a wood drill bit to drill through the perished old rubber to weaken them and clean up the remaining rubber that has welded itself to the wishbones with a hacksaw blade, use lots of grease on the threaded bar as the tension will strip the threads. Looking at your picture, you need to keep everything in line when trying to remove the old bushes, looks like your trying to pull it out sideways.
Edit, I just looked at the pic again, it might have been taken after removal, keep up the good work.
Found a vid, might help https://youtu.be/P7PvxtVLTKs
Postby notch000 » Sat, 29 Apr 2023 5:31 +0000
The picture is one I got thru ok, the middle bar is just a bit of iron I used as a stopper for the end nut, the first couple of attempts with an aluminum bit just folded in on themselves
On further analysis looks like the extreme effort in removing was likely caused by this ridge of surface rust & bubbling. It came straight off with one pass of a dermal & grinding wheel.
https://photos.app.goo.gl/nwBSDBwmKGTPmaAu5
notch000
Postby Steve » Tue, 09 May 2023 10:39 +0000
good to know!
I've melted some out in the past with a small blow torch, its messy and smelly though.
Since then I've just brought them and some beer to a garage with a press.
Postby mrges » Wed, 17 May 2023 8:14 +0000
Put Stripey through the NCT and got a TWO year ticket. That, and €56 a year road tax has made ownership all the more enjoyable!
Postby Pops » Thu, 18 May 2023 11:34 +0000
Good to get the 2years nct, did you have to explain that it is now in the vintage class or did they recognise it themselves?
I went for my test last night but they wouldn't test it, he said i was too early for the appointment,,,, by a week, idiot
Postby Pops » Tue, 23 May 2023 10:55 +0000
So, in preparation for the test tomorrow night I gave it a 100km spin, drives well but feels harsh on the road, all new bushes etc but tyres are at 26psi, anyone using less pressure?
Connemara still looks good Image
Original radio lights up nicely even though it is pretty useless even with a band expander
Postby Pops » Wed, 24 May 2023 9:44 +0000
Passed the NCT no bother except the advisory for age of front tyres, anyway, will be interesting to see what they say in two years time
Postby Eunos MX-5 » Thu, 25 May 2023 12:12 +0000
Pops wrote:Good to get the 2years nct, did you have to explain that it is now in the vintage class or did they recognise it themselves?
A bit too eager :mrgreen:
Eunos MX-5
Postby Pops » Thu, 25 May 2023 9:44 +0000
While watching him doing the test I had to turn away when he started poking the underbody lookin for rust, he didn't find any.
Postby Len » Fri, 26 May 2023 11:56 +0000
I know that feeling. Well done on the test. The car looks great. v cool stereo.
Len
Postby Pops » Fri, 26 May 2023 12:10 +0000
Thanks Len, 2 years test now so happy days. Took a long time to find the original radio and to be honest I only wanted it for originality as everything else is more or less original (ish), dont normally listen to it but I'm thinking of replacing it with a modern one with sat nav etc
Users browsing this forum: Bing [Bot] and 2 guests
