oil filter!!!!!my god did i have some fun trying to get my oil filter off last friday. after about an hour and a half i finally got a bit of grip with the oil filter wrench. does any1 have any easy remedy for this in future?
I find a bit of wet n dry paper over the filter allows you to get a good grip on it. Worked well on the last couple i did.
I hear (I haven't tryed) but if you replacing the air filter like what i'll be doing soon, you can use a screw driver... striaght through... Good Idea me think
Never knew what fun was till I found the MX5
ill have a try of the wet and dry paper next time anything would have been easier than what i did.
the screw driver straight through was definately on my mind but there wasnt much space at all to do it
I tried the screwdriver on the starlet and it's not that easy to drive a screwdriver through a filter whilst its still in the car. This is when i started with the sandpaper and it came straight off.
On the Mk1 there's a metal support bar which runs beside the oil filter up to the throttle body, take it off and you'll be able to get a full hand around the filter.
BTW you don't have to put the bar back on, it's not really needed.
Help!!! I need help. I messed my oil filter so bad that I can't drive. I was trying to remove it and don't have the proper tool. so can some one help me? I'm in swords. I have a new oilf filter I just need to get it off and I'm to week to twist it. can't actually get in there... HELP!!!
Thanks... sorry Never knew what fun was till I found the MX5
tried turning it with a rubber glove on?
I've used the screwdriver method in the past (punch/hammer screwdriver through the filter).. messy tho You could also pick up one of the chain/rubber band type removers from most motor factors.. This is what they look like : http://search.ebay.ie/search/search.dll ... ter+wrench Also, you could put the car on jackstands and remove the driver's side wheel.. might get a better angle on it.. Steve
OK well I got the right tool today but It was for audi and other cars. so to big for me. So I have to go back and change it... Arg. I took the wheel off. not good. and now the out side of the filter is messed from the screw driver method...
The screwdriver method didn't work?
heres more on it : http://answers.yahoo.com/question/index ... 059AAFEcJl
Hey all, robin and I managed to get the blasted thing off. I'll try get a picture of the stupid thing when I have a chance.
To two of use to hammer a screwdrvier through it. Not something I want to do again. Never knew what fun was till I found the MX5
