I drove mine today... top down of course!
Found lose battery bracket and fixed it, the drove it some more.
Re: What did you do to your MX5 today ?I drove mine today... top down of course!
Re: What did you do to your MX5 today ?new rear brake pads + clips, tightened handbrake, no more rattling
had an exhaust leak to took off and resealed turbo fixed indictor wiring, fog light and air intake temp wiring ground.
Re: What did you do to your MX5 today ?Washed it, cleaned out the inside, took apart the passenger window mech and cleaned it all and re greased it. Better than it was but still a little slow compared to the drivers side after it was cleaned. Maybe the cables are stretched?
Re: What did you do to your MX5 today ?Well, first I had to warm the oil by going for a spin with the top down.
Then I changed the oil. Then I went for a spin with the top down. Then I decided to change the plugs. Which I started to do before realising how far away the plugs are from the cam cover. So I went went for a spin with the top down - to get an extension yokey so the spark plug socket could actually reach the spark plugs. Then I changed the spark plugs. Then I needed to check the car still worked. So I went for a spin with the top down. It's been a very pleasant day. AKA Jeremy
Click below to check out my MX-5s in the Octane.ie garage: Formerly 1.8 S-Special in Black Now Cheap but Cheerful in Mariner Blue
Re: What did you do to your MX5 today ?Who'd have believed it?? Still able to drive top-down in mid October??
If global warming is responsible for this then throw another oak tree on the fire!! (Tongue firmly in cheek here before, the tree-huggers have a go at me) John
Re: What did you do to your MX5 today ?Fitted hard top for the winter. By God does it make a differance. Fitted my engine brace bar aswell. car solid as a rock. after that i changed the engine oil
Cheers Chris
Re: What did you do to your MX5 today ?finally got my EXHINTAKE mod done. Car pulls way better right up to limiter cutting in. Gonna play aroung with some different intake timing settings to get the best out of it. Well worth doing for a very cheap 10bhp. Oh, cut the valve cover too to reveal the pulleys. Looks like an old Cosworth BDA now. Pictures when i paint the pulleys.
Re: What did you do to your MX5 today ?fitted new steering wheel and ss sills washed and polished./ and went for a spin with the roof down.
Re: What did you do to your MX5 today ?The perfection of a Car's beauty is that nothing should be there for beauty's sake.
Re: What did you do to your MX5 today ?oooh, do tell: does it work ?
Re: What did you do to your MX5 today ?yes its the best mod ive done so far. The yanks reckon on 8-12 rwhp but theirs have less lift on the intake cams. Its well worth doing. Only works on the 1.8 tho.Takes about 2-3 hours.
Re: What did you do to your MX5 today ?Reached another stage in the dismantling of my beloved mk1..the front sub-frame came out. Now all that's left of it is the rear suspension and remaining body shell( minus the doors).and the rear lighting harness.
The big angle-grinder awaits!! John
Re: What did you do to your MX5 today ?Started fitting my polybushes. Drilled w/b's to take grease nipples so hopefully no sqeaking .
Re: What did you do to your MX5 today ?Took it out of the garage, and took pictures.
Bought it a couple of years ago as a rebuild project...but alas...plans have changed and emigration calls. So...tis for sale having never gotten to use it:(
Re: What did you do to your MX5 today ?Ah Jeremy, that's a pity. i assume it's posted in the for sale section?
Best wishes for the future, wherever it happens for you. Last one out, turn off the lights please. John
Who is onlineUsers browsing this forum: No registered users and 11 guests | ||
