Much drilling + jigsawing later
The material is a close enough match
Fitted (still needs a clean)
Door cardsBought some wood (B&Q < 4e) + leatherette (Hickey's < 10e), used old card/cover as templates
![]() Much drilling + jigsawing later ![]() The material is a close enough match ![]() Fitted (still needs a clean) ![]()
Re: Door cardsNice job !
You didn't go for the tartan then It's a small world after all. It's a small, small world
Re: Door cardsImpressive! So how long did it take?
Re: Door cardsNo, no tartan, couldn't find the right blend, maybe next year
Took about 6/7 hours over 4 eves, in hindsight I wasted too much time without a jigsaw + was way too particular about the wood/material shape cutting. I cut the material to the pattern of the old cover rather than just wrapping the new card and cutting off the excess/holes after it had been stapled down. If given a clear run at it I think it could be done a lot faster.
Re: Door cardsnice tidy job there steve matieral is good match
Re: Door cardsLooks well!
Recovered mine in diamond stitch vinyl last week, but wish i had made a new drivers side card like you did as mine is a bit warped!
