Importing Question !!
Postby Mel Walters » Tue, 31 May 2011 1:50 +0000
Hi Guys.
Has anyone else imported a Eunos Roadster with UK plates recently ?? I've just being charged €1,452 to bring my 1990 V.Special in. Think it's very steep as on the VRT site it quoted me €775 ???
Any feedback welcomed Thanks !!
Mel :P
Champagne taste ........... Lemonade money ...............
Mel Walters
Re: Importing Question !!
Postby leamyj » Tue, 31 May 2011 5:51 +0000
treble-check the underside!!!!!!!!!!!!
Postby Steve » Tue, 31 May 2011 5:59 +0000
You can contest the charge after payment.
Here is the procedure :
http://www.revenue.ie/en/tax/vrt/vrt-gu ... l#section6
It should be easy enough to obtain verifiable evidence on the 'net to support your case.
Best of luck with it, let us know how you get on.
Postby charged_rs » Tue, 31 May 2011 6:22 +0000
dont forget the transport costs coming from england.....
most transport companies will charge anywhere from £250 - £450 depending on where the car is coming from and being delivered to. ( ovbiously the further away , the more they charge)
Postby barney » Tue, 31 May 2011 6:44 +0000
my 5 cost €619 to clear in jan 2010. the open market value according to the revenue was €2582. is your car an automatic? you should have printed the quote and brought it with you.
Postby Mel Walters » Tue, 31 May 2011 9:20 +0000
Hi Guys
Thanks for the help. The car was bought here I didn't bring it in. I went today and they've put it down as a 1998 !!!!!!!!! That was the date it was imported into the UK so their mistake !! Hopefully now I've got the printouts I'll get a refund !! What should I be looking for on the underside of the car and are they common the V.Specials ??
Mel :P
Mel Walters
Postby barney » Tue, 31 May 2011 9:54 +0000
there should be a little square silver plate on the bulkhead above the engine. it should have the engine code on it. the code is the first 5 letters/nos of the chassis no. mine is NA6CE. i made a mistake earlier with duty i paid. it was €722, 24% of €3012. yours should be around the same. when entering the info on the vrt calculator you will also need the year and month of first registration which should be on the log book and if you have already handed that in put 6th or 7th month on it. they put yours down as a 98 because that is when it was first registered in the uk. good luck
Postby Mel Walters » Tue, 31 May 2011 10:11 +0000
Hi Barney.
Yes mine's the same as yours. Na6CE. I did print off the VRT for mine which came to €757 but as you said thay put down the import date to the UK !! How can I confirm that it's a V.Special ? Is this a rare car or a common model ?? Just interested !!
Mel :P
Mel Walters
Postby barney » Tue, 31 May 2011 10:31 +0000
just put in a june 1990 with 130,000kms and it came out at €757. gave me a statistical code 40180794. base price for jap imports more than 15yrs old is around €3000. cars first registered in uk have a base price of approx €2000
Postby Mel Walters » Tue, 31 May 2011 10:41 +0000
Hi Barney.
Yep that's the right price I hate being robbed !!! Unfortunately I didn't realise until they'd taken my money and tried to give me the 98 number for the plates !! So do you know about the V.Special model ??
Mel
:P
Mel Walters
Postby barney » Tue, 31 May 2011 11:08 +0000
common model and will make no difference to vrt amount. i cleared a van recently and the girl at the nct centre doing the vrt hadn't a clue what she was looking for under the bonnet, so not a surprise that they can't read a log book. :?
