Postby sidewaysreilly » Tue, 14 Feb 2012 12:27 +0000
thinners and atf mix for that one methinks.
Postby Steve » Tue, 14 Feb 2012 1:51 +0000
oh yes, forgot about that, will give it a go, thanks.
Postby indie » Wed, 15 Feb 2012 9:16 +0000
nct today.......passed without and probs whatsoever..........chuffed
indie
Postby franksm » Wed, 15 Feb 2012 9:48 +0000
Congrats on the NCT pass - always a good feeling after your motor's been under scrutiny !
Postby indie » Thu, 16 Feb 2012 12:50 +0000
franksm wrote:Congrats on the NCT pass - always a good feeling after your motor's been under scrutiny !
thanks.......also had the car jacked up today in the job and was under it inspecting for oil leaks around the diff and gearbox and noticed that i have a torsen lsd on my car, happy days. borla twin exhaust is next. :D
indie
Postby anniniwa » Mon, 27 Feb 2012 5:47 +0000
After cleaning all the mould down and draining the drivers footwell of a bucket and a half of water, I trickle charged my battery for a few nights took the roof down and took my baby for a well deserved spin. Called into Midlifecrisis for cuppa which turned into our first mini tech afternoon. Lots of cars being washed and both of Midlifes cars were reved up and shining.
I discovered where the water was getting into drivers side, not only one tear in roof ..but 4 around back window as well. So new roof required!! and can anyone tell me how to get rid of the smell of mould outta my wee babe? Twas grand on Saturday with roof down but god was i surprised when I had to drive with the roof up on Sunday..yuck!!!
Anyone know of a roof going, let me know!
Cheers
Ann
Postby sidewaysreilly » Mon, 27 Feb 2012 6:28 +0000
Same problem here. Roof shagged and floor damp. Lifted passenger carpet and the underlay was sapping. Stuck in a wee fan heater and its grand now. You will probably need to replace the underlay/insulation stuff.
Postby sidewaysreilly » Mon, 27 Feb 2012 6:58 +0000
Few bits ready for re-fitting.....
Postby back_in_black » Mon, 27 Feb 2012 9:07 +0000
Class job. Rear end looks brand new!
back_in_black
Postby sidewaysreilly » Tue, 28 Feb 2012 1:46 +0000
Yeah, put whole lot in the "tank" for a week and then prepped and sprayed . Lot of work but better than standard which was just a flash coat of paint.
Postby Steve » Wed, 29 Feb 2012 1:53 +0000
Looks like new!
Do you need to change the contents of the tank often/at all?
Postby indie » Thu, 01 Mar 2012 12:56 +0000
fitted the new component speakers one pasenger side today, removed the factory speakers and made up a mdf adaptor plate to fit the 6'' vibe speaker. the tweeter fitted directly into the existing hole where the dummy tweeter was.
ill do the rhs on me lunch break tomorow.
indie
Postby sidewaysreilly » Thu, 01 Mar 2012 2:19 +0000
no Steve, same mix for a while now if using a stainless anode. Water is clear as all the rust falls to the bottom.
Postby landmarkjohn » Thu, 01 Mar 2012 3:49 +0000
Totally impressed with this rust removal gizmo, it's like something out of Back To The Future, if you told me it was a Flux Capacitor I couldn't argue.
landmarkjohn
Postby sidewaysreilly » Thu, 01 Mar 2012 1:59 +0000
Yeah its easy and cheap and only removes the rust . Google it to find out more.
