Postby galwaytt » Wed, 07 Aug 2013 10:11 +0000
Jeez Steve....sure that's not upside down ? :)
from my SIII via Tapatalk
galwaytt
Postby sidewaysreilly » Wed, 07 Aug 2013 10:38 +0000
what happened the old one Steve?
Postby Steve » Wed, 07 Aug 2013 11:54 +0000
it needs a slight repair, must get round to it.
Three of the studs that I need for the new one are kinda stuck in it still, tried double nutting it and some heat but it looks like I'll need to pick up some new ones.
Postby sidewaysreilly » Fri, 09 Aug 2013 12:32 +0000
probably stretched like f*** anyway. Better off with new ones.
Postby Steve » Thu, 15 Aug 2013 9:09 +0000
Fitted a new oil return line during the week.
New studs arrived yesterday (thanks again Rhysmate!), got the turbo back on after an hour of 1/8 of a turn wrenching, then downpipe on and oil return/supply lines.
Postby rhysmate » Sat, 17 Aug 2013 12:37 +0000
Just pmd ya about the studs I've no phone atm glad they got to ya!
rhysmate
Postby peteh » Mon, 26 Aug 2013 9:30 +0000
Fitted an oem spec cabin brace from the later 1.8 mk1 to my 93 1.6, got this off stag on here, stiffens up the cabin/removes a bit of scuttle shake :-)
Image[/URL]
peteh
Postby fugs » Mon, 26 Aug 2013 11:28 +0000
Folded down the roof. Sat in. Started it up. Smiled. Turned it off. Put back up the roof. Smiled some more...
Mines a new purchase and not on the road yet!
fugs
Postby leamyj » Mon, 26 Aug 2013 5:36 +0000
fugs wrote:Folded down the roof. Sat in. Started it up. Smiled. Turned it off. Put back up the roof. Smiled some more...
:thumright:
Postby rhysmate » Mon, 26 Aug 2013 6:56 +0000
Haha I do that all the time. But I have to make the engine noises
rhysmate
Postby Steve » Sun, 01 Sep 2013 8:33 +0000
Replaced the intake manifold with one I cleaned out + painted last Oct.
Added some intercooler pipes and intake I'd also painted.
This was it before, so am happy enough.
Also, big thanks to RLtd and Merlot Man for their horse work installing the roll bar I had sitting in the shed since last Dec too! :thumright: :thumright:
Postby interceptor » Sun, 01 Sep 2013 10:12 +0000
Replaced manky diff fluid with silky Mobil 1 stuff.
Replaced rear Bilsteins with s/h pair from Robert Autocheck (top man) to cure seasickness.
Replaced the awful double DIN stereo (c/w Mini-Disc player!) with a new Sony xplod unit and storage cubby from mx5parts
Changed the plugs, engine oil and filters and managed to spill oil all over the floor. D'oh. Dear Santa can I have one of those fancy plastic drain pans...
Next week I'm ordering a style bar and proper blinging it.
'c
If you can't fix it with a hammer, you've got an electrical problem
interceptor
Postby sidewaysreilly » Sun, 01 Sep 2013 11:14 +0000
what intake is that Steve?
Postby Steve » Sun, 01 Sep 2013 11:56 +0000
Made by greddy I believe, supplied with FM kits about ten years ago. Referred to as dustpan intakes :-) want one? Can try and source one for you.
Sent from my GT-I9300 using Tapatalk 2
Postby sidewaysreilly » Mon, 02 Sep 2013 12:07 +0000
nah, wouldnt fit with the charge-cooler and piping but interesting cold air feed all the same.
