from my SIII via Tapatalk
Re: What did you do to your MX5 today ?Jeez Steve....sure that's not upside down ?
![]() from my SIII via Tapatalk Quick! free up some money for your '5 buy an energy efficient house ! One swallow does not a Summer make....neither is it long enough to put your '5 back together....
![]() Re: What did you do to your MX5 today ?what happened the old one Steve?
![]() Re: What did you do to your MX5 today ?it needs a slight repair, must get round to it.
Three of the studs that I need for the new one are kinda stuck in it still, tried double nutting it and some heat but it looks like I'll need to pick up some new ones.
![]() Re: What did you do to your MX5 today ?probably stretched like f*** anyway. Better off with new ones.
![]() Re: What did you do to your MX5 today ?Fitted a new oil return line during the week.
New studs arrived yesterday (thanks again Rhysmate!), got the turbo back on after an hour of 1/8 of a turn wrenching, then downpipe on and oil return/supply lines.
![]() Re: What did you do to your MX5 today ?Just pmd ya about the studs I've no phone atm glad they got to ya!
![]() Re: What did you do to your MX5 today ?Fitted an oem spec cabin brace from the later 1.8 mk1 to my 93 1.6, got this off stag on here, stiffens up the cabin/removes a bit of scuttle shake
![]() Re: What did you do to your MX5 today ?Folded down the roof. Sat in. Started it up. Smiled. Turned it off. Put back up the roof. Smiled some more...
Mines a new purchase and not on the road yet!
Haha I do that all the time. But I have to make the engine noises
![]() Re: What did you do to your MX5 today ?Replaced the intake manifold with one I cleaned out + painted last Oct.
![]() ![]() Added some intercooler pipes and intake I'd also painted. ![]() ![]() This was it before, so am happy enough. ![]() Also, big thanks to RLtd and Merlot Man for their horse work installing the roll bar I had sitting in the shed since last Dec too! ![]() ![]()
![]() Re: What did you do to your MX5 today ?Replaced manky diff fluid with silky Mobil 1 stuff.
Replaced rear Bilsteins with s/h pair from Robert Autocheck (top man) to cure seasickness. Replaced the awful double DIN stereo (c/w Mini-Disc player!) with a new Sony xplod unit and storage cubby from mx5parts Changed the plugs, engine oil and filters and managed to spill oil all over the floor. D'oh. Dear Santa can I have one of those fancy plastic drain pans... Next week I'm ordering a style bar and proper blinging it. 'c If you can't fix it with a hammer, you've got an electrical problem
![]() Re: What did you do to your MX5 today ?what intake is that Steve?
![]() Re: What did you do to your MX5 today ?Made by greddy I believe, supplied with FM kits about ten years ago. Referred to as dustpan intakes
![]() Sent from my GT-I9300 using Tapatalk 2
![]() Re: What did you do to your MX5 today ?nah, wouldnt fit with the charge-cooler and piping but interesting cold air feed all the same.
