andrew wrote:scallan wrote:
Sounds great, I must get the car out for one of these days.
Ya you should most fun i have ever had in a car
Re: What did you do to your MX5 today ?Car nct'd today, passed with flying colours.
Re: What did you do to your MX5 today ?nice one!
update: Not gonna make the retest deadline, so will end up having the car retested fully at a later stage. Local bodyshop guy is gonna tackle the job and fabricate a piece of metal about 4 inches by 1 inch and weld it in etc, we'll present it to the nct with primer coat only as he says that they don't want these issues to be dealt with by using fibreglass and fillers, they prefer to see metal being replaced with metal..i do have spare bodywork from which I could cut a bigger piece , but the bodyshop guy says that's not gonna be necessary..further update later . John.
Re: What did you do to your MX5 today ?Sorry to hear that John, I'm sure it will work out ok
Brian ]96 na Merlot edition. sold
Re: What did you do to your MX5 today ?4x1? Cool, could have been much worse (as you know
Today... fitted the fan washer jets from Ford, fitted new rear light gaskets, put the exhaust heat shield back on after a bit of high temp painting and cleared out the boot (it was full of parts/rags/jump leads/etc). rear light gasket old vs new ![]() Heat shield in ![]() can't remember the last time it was this empty ![]()
Re: What did you do to your MX5 today ?Got my timing belt and water pump done by autocheck. Really missed the car over the last since the power steering belt broke. Picked up a stainless grille too!
Re: What did you do to your MX5 today ?Removed the front brakes, then installed 1.8 calipers, carriers, discs and Mintex pads. My god, the difference...
Re: What did you do to your MX5 today ?Windscreen out
![]() Glad I didn't leave it any longer! The only indicator that there was an issue was the bubbling on that side, no bubbling on passenger side. ![]() ![]() Poked at the bubbling in the rear arch ![]() Bought a new rear wing panel and full outer sill from Moss, car now in for repair/welding + paint (yay).
Re: What did you do to your MX5 today ?AH Steve I wanted to burst that rust bubble !!!
Great to hear that's she's on her way for some panels and paint ,you were good to spot the rust in the windscreen pillers , I assume it will involve new metal being welded in ? Best of luck with it, give me a shout if I can do anything for you. I might be able to find some goggles if you still intend to drive it to the paint workshop ! Brian ]96 na Merlot edition. sold
Re: What did you do to your MX5 today ?yep, new metal going in, won't need too much though, most of that is just surface rust.
some progress on the wing + sill : ![]() ![]() ![]()
Re: What did you do to your MX5 today ?more progress
Re: What did you do to your MX5 today ?Passed its NCT on its second attempt. Failed the first time for having the standard rear red side reflectors
Re: What did you do to your MX5 today ?stuck a new set of wheels on today thanks autocheck
Who is onlineUsers browsing this forum: No registered users and 22 guests | ||
