Postby sifpilsen » Mon, 19 Mar 2012 10:25 +0000
Got some huge uniroyal rainsports (or was it expert), 195/65/14. Filling out the wheelarches. Nice ride comfort though.
x-'91 1.6
x-'94 1.8
sifpilsen
Postby peteh » Wed, 21 Mar 2012 5:33 +0000
Sprayed up my inlet manifold, air valve to match my rocker cover :
in the car :
Installed an inlet manifold thermal insulating gasket when I was putting the manifold back on, supposed to limit heat transfer from the head to the mainfold
Did the timing belt aswell, used a cam locking tool I got from Flyin Miata and a crank locking tool from Rennenmetal, made the job very striaghtforward for a novice diy mechanic!
peteh
Postby back_in_black » Wed, 21 Mar 2012 6:04 +0000
Nice job.
Could have done with that locking tool a few weeks ago!
back_in_black
Postby sidewaysreilly » Wed, 21 Mar 2012 7:41 +0000
Would there be any chance of scanning that tool to get one made up????
Postby sidewaysreilly » Wed, 21 Mar 2012 8:06 +0000
Nearly ready. Out in the fresh air again after getting all her giblets put back in.
6 Speed Box.
3.9 T2 Diff.
Rear Subframe completely rebuilt/repainted.
8.8 mhz crystal mod so i can use the power available at 7500rpm.
S/h Mohair Hood which was good value.
Billstein suspension with 200 front and 160 rear springs (old fronts) .
Bipes to fit and a good wash and polish.
Postby fobbzy » Wed, 21 Mar 2012 9:31 +0000
Well she looks gorgeous Mr Reilly..........
fobbzy
Postby charged_rs » Wed, 21 Mar 2012 9:58 +0000
those fm cam ninja tools are less than useful tbh, especially if you have to replace cam seals etc, i got one from fm last month along with a crank locking tool and a crank seal installer.
The crank locking tool is worth its weight in gold.
Postby sidewaysreilly » Thu, 22 Mar 2012 2:15 +0000
Thanks fobbsy.........
Postby s-mac » Sun, 25 Mar 2012 9:09 +0000
Finally got around to fitting my chassis rails today, cant wait to get the car back on the road now to see what kind of difference they make
s-mac
Postby sidewaysreilly » Mon, 26 Mar 2012 9:24 +0000
me too lad.
Postby s-mac » Mon, 26 Mar 2012 10:58 +0000
What did you do with the fuel line?
I still need to sort that, was thinking of useing the original brackets and some self tappers into the rails?
s-mac
Postby Steve » Mon, 26 Mar 2012 11:45 +0000
thats exactly how I did it, just had to bend the bracket out a little bit :
Postby Piers14 » Tue, 27 Mar 2012 8:09 +0000
The stainless steel is quite tough and it may be difficult to get a self tapping screw to work well. It may be easier to drill and tap the hole.
Thanks again for sorting this great purchase Steve. BTW, I bonded them in place with Tiger Seal which I'm hoping will add extra strength..
Piers14
Postby sidewaysreilly » Thu, 29 Mar 2012 2:58 +0000
luxury of having a MIG Welder. Roughly marked the rails in line with the origional bracket mounts. Drilled a clearance hole and tack welded a captive nut behind the rail. All mounted as origionally intended.
Postby peteh » Thu, 29 Mar 2012 9:26 +0000
Fitted a set of similar type rails today, got mine from a group buy on nutz, nice day for it
Hopefully will notice a little difference in the handling!
peteh
